Oscardeuce,
I guess it is obvious, but in case not, you should not fly it like that. If the handle does not return to neutral, the pump is probably continuing to operate, and you could burn it up, costing a lot more than O-rings.
Wasn't sure how far out your "upcoming annual" is.
