i do not know if this is the same problem; however i had fuel running out by the mechanical fuel controller on the rear eng (73p) the only way to stop it was to turn the fuel selectors off. the shaft to the engine has two "o" rings and the outside "o" ring was bad (this was a factory new controller with less than 100.0 hrs). very easy to fix, remove the controller, dissassemble the controller r/r the "o" ring, takes about an hour and no big deal for any a&p. never started a fire, was dripping on a 4 hr flight
