Unread 04-22-04, 10:00 PM
rick rick is offline
rick is an unknown quantity at this point
alt not working
hi, just went through this with a seneca lll. found the fues braker was bad and not letting current through. check the field post at the alt. if you are showing about 1.5v , this may save some time.check the pop out breaker and see if there is 24v on the hot side, then check the lead side and see what you are reading on the volt meter.
thanks
rick
