Unread 01-30-04, 12:44 PM
Kevin:
You've given me something to think about. I was told by somebody at CPA that the STC would allow me to remove the circuit board we are discussing. Now, I am wondering if that is true, or if the STC only allows replacing the Cessna ammeter (which I don't have in the first place). And I am intrigued by your thoughts on having both, although the diodes and capacitors on the circuit board are a source of continuous maintenance. I'll have to think about this.
When you put in the EI VA, where did you locate it if you left in the original circuit board?
Mark
Mark Hislop
N37E
