Jim,
In order to reach the interconnect hoses between the outboard and inboard tanks - where they go through the boom area - you have to remove a contoured cover on the bottom side of the boom about half way between the strut to the backside of the wing. As I recall it has about 24 screws and once that's off, there's a flat rectangular plate up inside above the trim cables with another ga-jillion screws... and as I recall, it is behind that plate where you'll find the hose clamps.
SKyKing
