Unread 10-02-03, 09:54 PM
WD-40 = STODDARD SOLEVENT
I JUST GO TO THE LOCAL BULK OIL PLANT WITH MY 2 GAL JUG AND GET MY WD-40 BULK. IT'S ABOUT $2-3 A GAL.
FOR THE REALLY BIG BELLY JOBS, I HAVE A SMALL 1/2 GAL WEED SPRAYER WITH A PUMP AND I GET THE JOB DONE QUICK. THE STODDARD EVAPS AND LOT QUICKER AND DOESN'T SMEAR AROUND AS MUCH. PLUS I DON'T HAVE THAT PROBLEM OF AN AEROSOL CAN THAT YOU CAN'T SPRAY UPSIDEDOWN. MY LITTLE WEED SPRAYER HAS A 3 FOOT HOSE. WORKS GREAT.
NOW THAT I FINALLY GOT THE FRONT ENGINE OIL LEAK FIXED I DON'T REALLY USE IT AS MUCH.
BTW, THE LEAK WAS THE HYDRAULIC PUMP INPUT SHAFT SEAL. TRICKY LITTLE BUGGER TO FIGURE OUT.
