Unread 07-31-03, 07:00 AM
P-Model
Kevin, I am sure the rates are that high because it is a press. unit. I have more than 1900 hours multi time of which about 1800 are in Skymasters with over 1000 hours in p-models. to keep insurance reasonable I only claim $125,000 hull and four seats and best rate I found was $3800.00. If you are going to compare the rates with a Baron, get rate for non-P model Skymaster. I am sure you will find the Baron much higher.
Cheers
Jerry
