Unread 05-23-02, 10:43 PM
Bob Cook Bob Cook is offline
N69S
Mark / Shadin
I have a Shadin as well, however, I found I needed to calibrate as after 6 or more partial fills, I found I was out be about 15 gallons per side (out of 74 gallons / per side.
I eventually made adjustments to more accurately reflect the actual flow. If you just fill the tank each time then I found the error to be within a gallon or two and within the accuracy of trying to fill the tank..
Guess we are dealing with accumulative errors and I was trying to compare notes. Not always able to just fill the tanks, consequently I end up with more fuel than anticipated.
Bob
