Unread 02-22-03, 03:07 PM
SkyKing SkyKing is offline
A better way...
Jim,
Assuming you have access to the A/C, take a very careful look at the nomenclature on the overhead panel surrounding the fuel selectors... it should be plainly marked. Better still, with the aircraft's Serial Number in hand, give Cessna a call and obtain a copy of the original "Weight & Balance and Installed Equipment Data" sheet for the aircraft as it left the factory. 316-517-5800. There's a minimal charge, but it's worth having if you've narrowed down your choice to a specific 337, then you'll know what the plane was supposed to have installed.
SkyKing
