Unread 02-14-03, 09:09 PM
re condensation
The rear usually runs warmer but when you take into consideration temps you need to look at the crankcase vrs the oil temp. Condensation occurs with difference in temperatures and existing moisture.
Either there is excessive moisture or there is a large difference in temp and condensation is occuring due to very low upper crankcase temperatures.
The cold oil filler extension can cause moisture and the later models have this insulated (in the p versions at least).
I tried to find the baffle information in my manuals and couldn't find part numbers. I have been told they do exist.
