What happens on ground when RPM is 1800 and you pull handle down?
Does it snap back to down after a few seconds?
Fyi you can put this on a T fitting on hose coming from pump for “testing purposes only” if you want to see live hydraulic pressure.
It sends bluetooth signal out and can be paired with ipad with their app.
Normal gear pressure is around 1500psi.
https://www.hydracheck.com/catalog/p...ging-5000-psi/
