Unread 06-18-25, 11:47 PM
After having the motor removed by my mechanic today, we discovered that the pin on the rotating arm had been sheared off. The arm has to be installed so that the limit switch can stop at the fulling open and closed position. It was not. So, we installed it again and found the correct position for the pin, now it stops at the fully open and closed position. @Mshrc, thank you for the help.
Karl
