fuel flow indicator
Rick
Could be defective sending unit, or it coud be some dirt foulded it up.
Suggest swapping sensor leads to unit then you know if it is the sensor or the unit.
My opinion it is the sensor at fault! Most of the circuit in the Shadin handles both inputs except for the pulse count (digital) from the sensor.
Most likely a dirty connector or poor connection causing the problem.
Is it intermittent or has it completely failed ?
