Unread 02-02-24, 12:18 PM
B2C2 B2C2 is offline
my rear cowl motor failed a while ago, and it was repaired. The failure actually was right where the wires entered the motor case, and I mention it here because the motor was rebuilt, and then failed again because the issue was a parted wire inside the insulation due to the twisting action so was intermittent. Real devil to catch so make sure you have whoever does the repair look for this. I found it by shifting the wires connected to the motor by hand when it was installed and getting it to fail. After install, make sure to zip tie these wires down to the motor case or frame nearby so the strain isn't applied at that entry point.
