Unread 01-23-24, 11:50 PM
kbecker kbecker is offline
I know some Cessna's have an adjustment at the spar attachment with the wing that allows you to increase or decrease the pitch of the wing (I'm probably not describing that correctly), but if the wings aren't set the same, you can experience a heavy wing situation. There is some kind of cam shaped adjustment there that can be rotated to make this adjustment.
