Unread 10-08-23, 08:18 PM
I used a single short jack on the jack point behind the nose gear. I have weighted the tail end down with cases of oil in a pinch (@8- 12 qt.) The nose wheel needs to be off the ground to service it. If you try to do it with weight on it, it will take 250+ psi to get it to move.
