Unread 10-04-23, 11:24 AM
B2C2 B2C2 is offline
One other thing, once you pull the breaker that will shut off the noise, you cannot raise the gear. I'm sure its a safety feature Cessna put in there to prevent gear up landings if the breaker is pulled or popped. So if this happens you have to raise the gear, endure the noise for a few seconds then pull the breaker. On my last flight when this happened I did this, then about 1/2 hour later I reset the breaker and no noise as the switch had dried out.
