Unread 09-27-23, 11:24 PM
I would tend to doubt that they would paint the parts. When I did it more than a decade ago, I recall the parts arriving pure white. Additionally, trimming, sanding, and even some heating was required to fit some of the pieces. After all that, then paint was applied.
The end result was far from perfect and I am quite the amateur at this kind of stuff, however it was a huge improvement over the brittle, cracked, and faded stuff that was original. I would attempt to salvage whatever you can of your existing plastic parts as fitting these replacements is no small task. No two Skymasters are the same so it’s probably not reasonable to expect to have production plastic interior parts neatly fit every airplane.
After I finished, I promised myself I would never do that again, and I haven’t.
