Unread 08-24-23, 09:28 AM
Gord Tessier's Avatar
Exclamation C-FTES gear up landing
All, on Aug 13, we had a gear up landing. The gear would not deploy, tried everything including adding oil to the gear pump that we had on onboard. All hydraulic fuid pumped itself overboard. Manual pump also pumped all the fluid overboard. Culprit was a failed nose gear actuator as per the attached photo.
Perhaps check yours for leaks etc. It's easy to overhail them and a lot less expensive then a gear up landing.
Gord
C-FTES
