Unread 07-20-23, 09:18 PM
GAdams GAdams is offline
Originally Posted by Kim Geyer View Post
I think they will open but not close. I’m not a pilot but maintained 6 for @ 28 years. You don’t need power to open them but you need power to close them.
That would make sense since on the ground you can pump the gear doors open with the hydraulic pump handle and when you close the doors on the ground you must turn on the master switch then pump the handle to close the doors.
