I would not use a Shadin or jpi to set up your fuel flows. You must/ should use a calibrated gauge to set it up. The K factor on a Shadin or jpi can get off and give you an inaccurate reading. If I remember correctly we had a past member crashed because his fuel system was adjusted using his electronic system. He didn’t survive.
