Thread: Sealing exhaust
Unread 05-12-23, 09:06 PM
Doing annual, exhaust leaks at cylinders, visual. Hooked up vacuum cleaner in reverse up the tail pipe, sprayed every joint with soap and water, minor bubbles are normal, mine was too excessive, manifold pressure was ok, just don’t like leaks, brass nuts continue to loosen up on cylinders, hopefully the Klincher nuts work better.
Dan
