Unread 03-22-23, 02:42 PM
chrisb chrisb is offline
chrisb is on a distinguished road
Electronic ignition is definitely part of the plan!
With regards to the autopilot, it's largely dependent on where we are with the whole avionics setup by the time we get there. Also where I end up finally registering the aircraft. There is a lot t legacy wiring and avionics to remove from the aircraft. I can't wait to get started on that part of the project but right now I'm holding off to get the base essentials fixed.
We're about to dismount the rear engine and then get both the engines sent off for IRAN. We'll then be able to do the top coat of paint on the body and get the wings into the booth.
P337H Sn: 0318.
Under restoration
