Unread 02-26-23, 12:13 PM
Good post. I've read that the 337 is the most abandoned airframe. Not sure if that's true, but it would be interesting to compare the percentage of airframes currently registered vs number built to get a "Percentage still active", then compare that percentage to other light twins of the era.
The same math could be done by model to determine which model of the 337 has the highest and lowest "Percentage still active". I would theorize that the later models have a far higher percentage active than the early models.
