Unread 02-04-23, 09:17 AM
What are your cruise fuel flow settings for your Turbo?
Last Sunday was cold and rainy, so I started compiling various engine and airframe performance charts into something useful.
While there are billions and billions of tables, does anyone really fly using them?
I think in reality we
1) set manifold pressure, then
2) RPM, then
3) lean, ...and away we go!
Beyond that is just obsessive diddling with things
One 'constant' is INDICATED airspeed at SEA LEVEL for a given power setting.
From that INDICATED airspeed one can then use math to determine TRUE airspeed, adjust for pressure altitude, temperature etc. But we can only adjust power for a shown IAS.
The TCM engine manual has tables for rich to lean, for example.
The table below shows the limits from the TCM engine manual for my TSIO 360ABs
QUESTION #1: With GAMI do you lean BELOW the 'lean' values in the TCM manual? or...
QUESTION #2: With GAMI do you just run smoothly at the SAME TCM lean settings?
Below is the user table I derived from the various tables and manuals.
Next time I have time to spare I will flight check reality vs tables.
The efficiency values to right are MPG and speed, vs baseline of 75% at ROP.
For example, running the engine 75% power LOP would get you 20% better MPG than ROP with no loss in speed. Running 65% power LOP is 24% better MPG, with a loss in speed of 7%, etc.
Comments? Comparisons?
SET IAS @ altitude GAL/HR KNOTS/GAL LOP LOP
MP RPM PWR MPH KTS 5k 10k 15k ROP MID LOP ROP GPH LOP +EFF -SPD
32 28 100% 178 155 - - - 42 40 ---
28 25 75% 173 150 160 169 177 28 24 23 5.4 6.3 6.5 20% ---
24 70% 169 147 156 165 175 26 23 22 5.7 6.4 6.7 24% 2%
26 26 70% 169 147 156 165 175 26 23 22 5.7 6.4 6.7 24% 2%
24 65% 161 140 150 159 169 24 23 21 5.8 6.1 6.7 24% 7%
22 55% 151 131 143 152 162 21 19 18 6.2 6.9 7.3 35% 13%
24 22 50% 143 124 135 144 155 18 17 16 6.9 7.3 7.8 44% 17%
