Unread 01-14-23, 06:23 PM
Went to the site and saw a “speed handle” pop right up. Neat trick I learned on mine from the mechanics is a Phillip bit on the speed handle. Soak screw with oil, put lapping compound on bit to increase traction on screw and rock back and forth tightening and loosening.
Surprisingly you can tighten sometimes to break the screw loose.
