Unread 11-30-22, 11:43 AM
Originally Posted by CO_Skymaster View Post
I have an EI MVP50-P on the front engine that was reading some impossibly high number on the Manifold Pressure (1400Hg instead of about 21Hg). EI said to check the Manifold Pressure sensor and connections to see if it was malfunctioning, which I thought would be on the intake manifold after the air filter. I could not find the sensor location. Can someone tell me where the MP sensor would be on an IO-360? Is it in some unexpected place?
I've been trying to learn more about where some items are on my aircraft, so I don't have to rely on getting it into the shop anytime an issue comes up.
Karl
According to EI's instructions on their website,
"Manifold Pressure Transducer Installation:
Mount the PT-30ABS Pressure Transducer on the inside firewall or in the equipment bay under the aircraft instrument panel."
