Unread 09-29-22, 12:21 PM
Ditto. I also have 790. I thought I could slide it in in a mirror position of your 760 on the copilot side, bottom left where there was a second altimeter. But when it arrived, screen to big. Likewise I ended up putting it in center stack lowest position. Your location too tight for the offset screen.
You could move your OAT and put it there. Or use the 790 to replace the OAT; it has an OAT function
That's not a bad suggestion. Not an ideal sight line, but the original OAT gauge hasn't been super reliable, and if the EDM has an OAT, then that would be a good replacement. I don't currently have OAT on my 760, maybe its not enabled?
So then what to put into the empty hole where the 760 was? A G5 maybe?
