Unread 09-11-22, 04:46 PM
I have attached the relevant pages from TCM fuel pump rebuild manual I had previously found on a Beech Owners website. Open PDF.
For the seal, I looked it up and seems aircraft spruce has it in stock! Learn something every day!
But, if that rubber wore out, something else in the pump might be at end of life as well. At least changing the seal could get you home.
File Type: pdf TCM fuel pump 360 series cessna 337.pdf (446.1 KB, 2655 views)
