Unread 08-17-22, 08:14 PM
Post Leaking Rocker Covers - DON'T OVER-TIGHTEN
I have the orange soft silicone gaskets - If you have cork gaskets, this does not apply to you.
My rocker covers were leaking oil, so I grabbed a big screw driver and tightened them firmly. I then started the engine to check if it was still leaking, and it had gotten worse!
I couldn't understand what was happening, so I did some research and found that the silicon gaskets have very specific torque values and install instructions.
Install the lower two screws first. The torque limit is 25 inch-lbs when first installing the gaskets, then re-torque to 20 in-lbs after running the engine to full power, or first flight. These are not high torque values!
25 inch-lbs is equivalent to only 2.08 foot-lbs. To get these values correct, you have to use a "Torque screwdriver" with an inch-lb scale.
When I over-tightened the screws, I actually deformed the valve covers! The area around the bolt holes gets bent down, so the cover isn't flat anymore. You have to hammer them back to flat which can be a challenge without the right equipment.
I ordered a new set of gaskets from Real Gaskets.com. They are $5.50 each plus s&h. https://realgaskets.com/product/valv...asket-4-holes/
Gasket installation instructions: https://realgaskets.com/wp-content/u...roved-2018.pdf
I've ordered this torque screwdriver to use upon installation: https://www.amazon.com/Screwdriver-M.../dp/B099N5VY7P
