Weight and Balance issues
I won't go into too many specifics other than highly modded 1975 T337G.
Empty weight 3702.47, CG 136.68.
When I enter my weight of 190 lbs I can't even fill the 148 gallon tanks to full without going over gross and the CG is too far forward... you couldn't put two standard 170 lb adults in the front seats and fill the luggage area a max 160 lbs to compensate!
Am I entering the data wrong?
