Unread 06-27-22, 07:34 PM
GAdams GAdams is offline
Savvy
Your lists looks appropriate. I would use Savvy based upon what I have seen and been told about the companies reputation. I personally have no first hand experience. Best to analyze before "attacking with tools"
The fellow with a 55 PSI cylinder. I wouldn't condemn that cylinder right away without doing a borescope. Followed up by lapping the valves if the borescope inspections leads you to believe a valve problem exists. Burnt valves also can be corrected without removing the cylinder in various cases. Again look at the information from EAA/Savvy on YouTube and go from there.
