Unread 04-27-22, 01:28 PM
rmorris rmorris is offline
Landing gear doors
I saw the other thread that talked a lot about LG door removal STC, and I guess that's worth considering.
But here's the problem, lmk thoughts:
Gear down cycle, works great with no issues at all. Everything goes down, doors close and lock in place, green light, handle kicks back to neutral. All good.
LG up has an issue...handle up,doors open , wheels go up,doors close, amber light comes on...then doors immediately fall open. Handle never returns to neutral, amber light stays lit.
Manually return handle to neutral and then can pump doors closed.
Initially thought it was just low on hydraulic fluid. So topped it off. It was low, but now full...issue still exists.
Thinking that if it was a wheel microswitch, the amber light wouldn't light up.
Thoughts on things to check?
