Unread 12-21-02, 06:42 PM
John C. Noone John C. Noone is offline
John C. Noone is on a distinguished road
right brake leak
Hi Dave,
Have your mechanic check the fexible brake hose
that connects from the bottom of your master cylinder to
the solid brake line in the belly.You must remove front seats
and all front floor access panels and inspection plate to
gain access to this hose. It is probably holding pressure
untill you step on brakes and then it fails again and leaks fluid,
Hope this might help you if it is the problem. If this is it you must replace it to solve problem. Bleeding the system will only bring brakes back temporarily until added pressure makes the hose
fail. This may not be the problem but it is worth checking out.
John
