Unread 03-24-22, 11:06 PM
CenterlineT CenterlineT is offline
CenterlineT is on a distinguished road
Canadian Aero - $2000 OH https://canadianaeromanufacturing.co...classic-style/
Quality Aircraft - $1495 https://www.qaa.com/products/aircraf...tarter-adapter
Found an outfit in Hamburg Germany that claims to OH them as well.
There may be others but I found these three rather easily.
Best wishes.
PS - There is an old wives tale that says not to run Camguard in Conti's because it will ruin the starter adapter. NO idea if there is any truth to it.
Thanks.
The problem with cam guard and synthetic blend oils are that if you run straight weight for a long time and then switch to adding cam guard or switch to synthetic blends the problem starts. But if you run them from new with synthetic blend and or with cam guard the adapter should last a long time.
I have ordered some parts and we shall see how it goes and will report back.
Thanks everyone with your responses.
