  #34
Unread 02-22-22, 08:47 AM
PatrolPilot: The Alternator Restart System is pretty simple. I rebuilt mine from the ground up.
I've attached a highlighted shot of the schematic showing the system. This schematic shot is from plate E22.
If I'm remembering correctly, you have a G model, you still have the installed switch, and you already have the Service Kit that gives you the 4 C-cell battery pack. You just need the:
  • Resistor, (#9) and the
  • Two diodes (#12)
Plate E19 shows the:
Resistor to be a 12 ohm, 1 watt resistor, and
Diodes to be an F4, which was superseded to 1N2070. Both are readily available from eBay and Amazon.
Getting to the parts on my P model was a PITA though. I don't recall if you have a P though. The stuff lives above the pressurization panel behind the behind the switch.
Rick
N337K-FT337GP
KLOU
