Unread 12-27-21, 10:58 PM
When you adjust mixture, it moves a lever on the fuel pump. It would be interesting to see if setting the mixtures to a sample position you’ve experienced in flight, results in a position of the fuel pump levers that match. If so, a linkage problem. If not, pump adjustment may be in order. Continental has a procedure for that.
