Unread 12-18-21, 10:55 AM
hayesjaj hayesjaj is offline
Sorry, I don't have any pictures of the "surgery", but it wasn't too bad. the lower switch panel (grey in picture) comes and blocks the rack extension if you want it longer and to go down further. You can't see in the picture as it is behind the instrument panel edge (in black), but had to trim some of that lower grey panel where it interfered. once you go to install, it will be fairly apparent.
I think I did the "trimming" with a file and maybe some tin snips or a hand nibbler. You will also trim the RadioRax to length. I went as long as I could go on the RadioRax. Just take your time, however, not a tough job at all.
That's great, thank you! Cessna really made lives difficult in the 73 and on models by changing the panel structure from the fully removable face to an integrated structure. Part of that change involved integrating the avionics support rail as a flange on the pilots side. I suppose we will need to cut this away entirely to make it fit. See attachments for what I mean.
