Awesome! Cheap and easy. How did it get loose? Not tightened enough first time? Or aging of the o-ring and back up ring made it loose compression/tightness. Maybe a prophylactic front o-ring change due too?
In the video....is that fitting not exactly straight and lined up or is that just an illusion? Could that be contributing to the initial failure? Doesn’t look like the compression nut is completely flat. Might just be my imagination not seeing it in person.
