Thread: Alcor EGT
Unread 12-16-02, 05:02 PM
Bob Cook Bob Cook is offline
re egt
Wayne
There is no electronics or amplifiers involved with this guage.
If I remember correctly; I don't remember the peak reading being much above 1/2 to 2/3rd full scale.
maybe someone else on the board can verify the readings.
The Front adjustment was meant to "balance" the readings at peak so it is a little easier to remember "normal" settings.
you can check the calibration by carefully using a flame and measuring the peak temp of the flame. Both reading should be similiar in no wind conditions. just be careful using an open flame from a small propane torch.
Bob
