part numbers
Awesome!!
Do you have the o-ring part numbers you can share? I would like to do mine as when the valve is off, the fuel from the port side main tank drains back into the reserve tank and then out the overflow. If both tanks are full, it will leak over 10 gallons in a week before the pressure is low enough to stop the flow. So I now I park it with full main tanks and empty reserve. I prefer to keep them all full.
Thanks!!
