Unread 11-12-21, 07:16 AM
YankeeClipper's Avatar
From the ACS for private pilots, updated 6.6.19:
Removal of the “Limited to Center Thrust” Limitation
The “Limited to Center Thrust” limitation for the AMEL rating is issued to applicants who complete the practical test for the AMEL rating in an aircraft that does not have a manufacturer’s published VMC. When conducting a practical test for the purpose of removing the “Limited to Center Thrust” limitation from the AMEL rating, the applicant must be tested on the multiengine Tasks identified in the table below in a multiengine airplane that has a manufacturer’s published VMC speed. This speed would be found on the type certificate data sheet (TCDS) or in the AFM. If the limitation will be removed under parts 121, 135, or 142, it must be done in accordance with an approved curriculum or training program. An applicant who holds an airplane instrument rating and has not demonstrated instrument proficiency in a multiengine airplane with a published VMC shall complete the additional Tasks listed under Removal of the “Airplane Multiengine VFR Only” Limitation section
