Unread 10-15-21, 07:39 PM
Post Skymaster Project to be Auctioned Oct. 30th
NO RESERVE AUCTION - MAY GO VERY CHEAP!
"65” Cessna CE-337A Super Skymaster N-6250FS/N 337-02503472 Hrs. Total Time Front Engine S/N 50251-5-C 1870 Hrs. S.M.O.H. Rear Engine S/N 55264-5-D 1870 Hrs. S.M.O.H. Starter Off Rear Engine, Prop Off Rear Engine at this Time but is Available. Last Annual 11/15/2003 Aircraft Had a Gear Up in 12/2/96 with 2138 Hrs. T.T., Engines Went Through Prop Strike Inspection at that Time with New Cranks, Reground Cams, New Rod& Main Bearings, New Lifters Avionics: Terra TMA-340-D Audio Panel King KX-155 Nav Comm Narco AT-150 Transponder Narco 190 DMEKing KR-86 ADF Apollo GX60 GPS/Comm400 Auto Pilot
NOTE: Aircraft will Require Work to be Made Flyable, so the Buyer Will Need to Take the Wings off & Trailer Them out of the Sale Site.
http://www.starmanauctions.com/index...filter_reset=1
