Unread 06-02-21, 01:57 PM
Insulation in the rear air inlet housing, or wing to fuselage cavity?
Have any of you seen, or have, fiberglass insulation around the rear engine air inlet?
How about in the space between the both wings and the fuselage under the fairing strip?
I have fiberglass insulation in those three locations. I don’t see the use for it and can see no reference for it in the parts manual. I think it could retain moisture and could generally be detrimental.
Should I remove it, or keep it?
Rick
File Type: jpeg ABA84CB2-663E-4B9F-A358-72A410B11359.jpeg (302.4 KB, 3076 views)
N337K-FT337GP
KLOU
