Unread 12-08-02, 10:21 PM
Bob Cook Bob Cook is offline
N69S
re diesels
Diesels are a different breed of animal. Problems are;
1) diesel fuel congels at lower temps.
2) engines hard to start or restart at low temps.
3) I would assume that normally aspirated diesel power falls of rapidly as altitude increases (worse than gas engines).
4) harder to air start due to the compression ratios being above 12:1 (typical).
The Germans prior to wwII manufactured some rather large diesels but eventually were displaced with lighter (hp/weight ratio) gasoline aircooled engines.
I would assume there would be some vibration problems to overcome when the engines are full out.
just some thoughts.
bob
