Unread 05-17-21, 08:23 AM
saxbill saxbill is offline
saxbill is on a distinguished road
Originally Posted by Trippster View Post
Thanks, that makes a lot more sense to me, but I am not mechanical at all. I'll just specify the 2 tanks and I assume the wiring will tap into the conditioner box for the value. Appreciate the help
I spoke with EI about a similar question. On our 337D, the mains and aux are separate, so there will be separate displays for the main/aux. However, the mains actually have two tanks on each side and two senders for each side (6 senders total if you include the aux tanks). EI said that you will need a sender for each physical tank and they will provide an extra interface free of charge to combine all of the signals from each sender (so in my case for the mains) into on signal that will go to the CGR30 EDC. Given this, I'd say you would just need total usable per side.
