Unread 04-27-21, 04:43 PM
bking bking is offline
bking is on a distinguished road
Learjetter,
I placed an order with Computer Components but they only had 1 in stock with a 3 month wait for the second relay. I searched the web and found another for $225.00 along the 4 resisters at Wilco.
Long story, but I also found a new surplus PC board for $175.00. After finding the board, I decided to make up a new unit and ordered all new diodes and the MS terminal boards.
The only 2 items that I could not get in the correct part numbers were the fuse blocks and 7 position bottom terminal strip and, according to Cessna, they are no longer offered. That said, I found similar components with the same ratings and also have them on the way.
I should have less than $700.00 total in parts for a new board. New surplus and "as removed boards" were running from $2,600.00 to $4,100.00 so, I'll have some fun and save a few coins.
If you could post a photo of your board it would be great and thank you,
BK
