  #27
Unread 04-01-21, 07:52 PM
hayesjaj hayesjaj is offline
Just FYI - - I've got some FAA airworthiness guys working with DER/DAR at EI to get the EI CGR-30P approved for skymasters. Eventually, EI wants the 337 on the AML for the CGR-30P combo STC. No word yet on completion dates for the project, but EI is working on it.
My cluster gauge is on its way out the door (bad CHT gauges and senders with no replacement available, cracked glass, etc) so I am going to do the cluster replacement with my 73G model first. I talked to Blake from EI and he confirmed that I could do that and install two EDC units, one for each engine, then install the other instruments later. Still needs a field approval, so when I get some clarity on that I'll post back.
