Unread 02-28-21, 05:26 PM
To Rick,
I'm getting closer to purchasing my MVP-50's. EI said they might have a rebate program in place around Sun-n-Fun in April, so I'm targeting that time. I would appreciate if you could answer 2 questions since you already bought one.
1. I noticed on your picture, you have an ALT1, ALT2, BATT, and BUS. My Skymaster has a switch that changes from REG1, REG2, and BATT. I guess that is for the pilot to switch since there is originally only one Volt meter. Did you remove that switch and this is how your system looks at the voltage pickups.
2. Did you use the EI P-300M fuel sensors. My mechanic recommend a fuel sensor, but it's twice as much as the EI sensors. I just wanted to know if you bought those, if you are satisfied with the sensor.
Thanks for any help,
Karl
