Thread: Wtb
Unread 01-14-21, 07:56 PM
Just go with the LORD mounts. If you go to all the trouble of changing engines then of course you would use new mounts. They are not cheap but they will be on there for years so think about 10 to 15 years of use and the price is not so bad. When you say cables are you referring to the battery cables? You have the flat web ground cables on the mounts and those should be fine unless they are damaged or corroded
